Zum Hauptinhalt wechseln
Die dritte Version von Canons Kompaktkamera-Design mit Superzoom-Objektiv. Ursprünglich veröffentlicht im Februar 2006.
LCD screen cracked. Replacement process?
The screen on my camera is cracked.
The screen will not come on at all right now.
I would like to replace it.
I found the blow-up diagrams but is there a correct process?
Do I also need to replace the Back Light Unit?
Thank you in advance for your help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@nanaburt yes there is and all you have to do follow it in sequence as outlined in this document S3-Disassembly.pdf
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank You oldturkey03. I have the diagrams, Can I start at the point of taking the LCD cover off (after removing the battery) or do I have to remove the screen at the hinge before taking the cover apart?
von Teilen
... also ... are there any precautions on where I should NOT touch as I remove the PBC Assembly as I need to re-use the current one if possible.
von Teilen
@nanaburt this does look complex but at this point I'd follow the individual steps as they are outlined. Stay away from the flash cpacitor since it does pack a punch. You should always discharge that one before working on a camera. I do try to not touch all over the pcb but there is only a small chance to either shorten things out or cause damage due to static electricity.
von Teilen
Antwort hinzufügen
Gale wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 616
