Zum Hauptinhalt wechseln
Ein HP Pavilion Laptop mit 15,6" Bildschirm, gutem Klang, einem leistungsstarken Intel 5 Gen Prozessor und schlankem, stylischem Design. Dieser Laptop ist gut geeignet für das Surfen im Web, Textverarbeitung und andere einfache Aufgaben. Er lässt sich anhand der Modellnummer identifizieren: 15-ab165us.
6 Fragen Alle anzeigen
Cant connect to some wifi
My hp pavillion 15-cc1xx which was not listed on the select device menu will not vonnect to some networks. It works fine at my home network, but just says no internet, connected when i connect to my school WiFi. The schools WiFi worked perfectly fine 2 weeks ago but now refuses to work.
I do not use Ethernet at home and can't at school and the windows diagnostic hasn't helped.
If anyone has any suggestions id love yo hear them.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hello, it can be software or hardware problem. Use any bootable OS from FlashDrive and try WiFi connection, if it works, then try to update drivers on your original OS. In some cases it may need to reinstall OS. IF it hardware problem - replace WiFi card. Looks like it due to WiFi frequency. Hope driver update will help you! You can find correct drivers for update using original manufacturer(of WiFi card, not laptop) website, or from HP website, maybe OS can update driver correct itself. To get driver from original manufacturer website you need get device ID from system settings of your OS, or remove WiFi card and read it from label. Best regards!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
James Parrow wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 292
