Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Is my battery at fault?
I've inherited an iPhone 6 which a friend has recently upgraded from due to "battery problems", as I was told, and I'm trying to get it back into a usable state. When not connected to power, the device remains powered off completely. When plugged into power, the device seems stuck in a boot loop. It powers on, light grey background with Apple logo for about 15 seconds, then screen switches off for a couple of seconds, then back to the first screen.
I can put it into standard Recovery mode, but attempting to Restore & Update results in an error 4013. Putting it into DFU mode and trying the same gives an error 4005 (eventually, takes a lot longer). Tried on both Mac and Windows machines, a couple of different cables, just in case, but identical results. Device has no sign of any physical damage.
Now my question is: Does this describe a situation where the battery has (effectively) died, and what are the odds that replacing the battery will give me a fully functional device?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
4013 and 4005 are NAND related issues, the memory chip on the logic board needs to be at least removed reballed then reprogrammed. All done via board-level repair / microsoldering.
It's probably going to be hard to find someone in your area that does that job as it's very tedious to do.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
That would be annoying. Curious that Apple's KB article for those errors seems to indicate that retrying with different cable/computer/etc may resolve them (but then that's Apple's answer to most things). Was really hoping a fresh battery would solve all my problems. Any idea the ballpark price I'd be paying for your suggested fix? Might be better stripping for parts.
von
$120-$180 around there. Requires more work than replacing charging chip.
von
Antwort hinzufügen
Endareth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 74
