Zum Hauptinhalt wechseln
Repair guides and support for the first generation Chevy S-10 (4WD model T-10) Blazer, a mid-size SUV based on the S-10 pickup truck. Closely related to the GMC Jimmy.
21 Fragen Alle anzeigen
Heating Wires N Stuff
The panel that is directly below where the heating A/C buttons , that you can take off the panel thing and there's a bunch of wires and stuff behind it. I'm trying to figure out what the wires & panel/section itself is called so I can order it all new because a bunch of the wires are frayed or messed up & some of the connection things too.
I'm going to link to a photo of the area I'm talking about.
Link to photo
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@lusciously that is where your ashtray and the auxiliary power outlets (cigarette lighter) are usually located. As for the wiring, you would need to get complete new wiring harnesses etc. At this time I would not replace those. Get some electric tape and cover the areas that appears frayed to you. Replacing a wiring harness is a major undertaking. Only replace it if absolutely needed.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kimi Tee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 57
