Zum Hauptinhalt wechseln
Erhältlich in drei Größen. Die rotierende Warmluftbürste lässt sich anhand der Seriennummer BC178RBCR identifizieren.
My air brush doesn’t spin.
Hi,
My Conair pro airbrush turns on but doesn’t rotate.
Please guide me on how to fix it thank you.
Thank you
Ist dies eine gute Frage?
Bewertung 7
5 Kommentare
I had the same issue with the two I have had. It’s so frustrating
von
I gave the "neck"a little twist to the right and that got it going
von
I have the same issue too. When traveling Norway, my Conair rolling hair dryer had much more power and heat than when home in the US. It was faster and wonderful, but it quit rolling on day 2.
von
I fixed mine through determination. Mine had 2 tiny caps on the side of the upper handle. After I managed to pry them off I found two screws. Undid those and the brush came off. There is a very s air rectangular shaft inside and I think it had come unlocked. Tried it before I put tiny screws back in. It is working fine now. No, the top cap does not come off mine. Turned out to be a simple fix if you can get those two tiny plastic caps off.
von
Got mine opened thanks to Pat’s instructions above. Definitely the little shaft is turning very slowly, so not hair tangled in brush problem, but I could not figure out how to do anything with it. What was meant by “had come unlocked?” Everything seemed to be in place and did not move when I tried.
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
It is probably stuck with hair.
Twist the top cap counter clockwise just a bit to unlock it.
Remove the cap and remove any hair.
If you unscrew the the small bolt on the top, you can remove the brush and take away the remaining hair.
It started spinning slowly, I let it spin for a couple of minutes and It started working again.
War diese Antwort hilfreich?
Bewertung 2
10 Kommentare:
It doesn't spin looks to be jammed or he left right spinning buttons are not working. How to open open them?
von
how to take off motor plastic case?
von
That is my question too. The cap doesn't budge for removal.
von
the cap is stuck on how do I get it off? It will not turn counter clockwise or clockwise.
von
Having the same issue and can’t remove the top cap
von
5 weitere Kommentare anzeigen
My conair won't go to hi. Just low feature. Is it supposed to do this?!
Bewertung 0
Sorry my doesn’t spin either. Just bought it threw the receipt out before trying, stupid I’ll never do that again
Bewertung 0
I have bc178 for about 4 years of not heavy use and from last year randomly it won't spin until I help turning it by hand than it start strong without stop unless I changed the rotation.
Now it becomes very weak and lost it's torque.
I disassemble it and there where no hair involved.
For disassemble in below order,
Two black cap for screw on base of brush and the two screws, brush, the black plastic ring at where brash attached to body, air intake cap and ring, cord ring, cord, black piece that main key is on it by poping it from cord side. Than the rest separate into two.
The motor is 24v brushed equipped with a gearbox. Quick search find it only on Alibaba and not selling for consumers.
Need to redo the soldering and loose two screw on motor housing to remove the motor assembly from heating element.
Didn't find and cosmetic damage and discoloration on electronics.
I am thinking of both bad diode that kill the current at motor and the motor brushes. Than the short brush doesn't have anything with low torque.
Bewertung 0
I gave mine a little twist at the neck and that got it going again.
Bewertung 0
1 Kommentar:
It's gonna take about hundred neck twist to call it dead.
von
Antwort hinzufügen
Shirini2@gmail.com wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 61
Insgesamt: 10,023
