Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Why is the cameras and flashlight not working after drop?
Hi.
Yesterday I dropped my iPhone 6s. And when I picked it up nothing happened - at least what I could see. When I came home I realized that both cameras and my flashlight weren't working.
The phone has not been in contact with water.
The earpiece speaker is working.
Any ideas what I could do to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I recommend trying the front camera replacement first as this is usually the one at fault when both cameras don't work.
Just that the apple devices in particular may stop both cameras from working when the front camera is not working but rear camera works.
Both cameras never appear to go faulty at the same time. If you get the camera too hot warning the issue is related to camera ic bad. It can also be caused by liquid damage bottom right near the rear camera connector area too.
War diese Antwort hilfreich?
Bewertung 2
Just replace the camera, it probably broke. I assume you're talking about the back camera, so the speaker is not related to it.
Bewertung 1
Antwort hinzufügen
Anders wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 8,454
