Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
No Light on screen totally black 5s
Hi,
The home button on my iphone 5S was not working so I thought I would open it up and have a look. I wasn't able to fix it so I decided to close it again but the screen was just black although it did vibrate and it could receive calls ( i just couldnt see anything on the screen).
I decided to open it again and check the connections from the LCD screen to the phone, I took all 3 of them out and put them back in but that still didnt work. I did notice that when I pressed the switch off button, the light did come on the actual LCD screen but just not on the phone. Also when I re fitted the LCD wire to the phone, it made a vibration. All the connections seem fine and the backlight does come on. Can anyone help me as to how I can get the actual screen get the light and touch. thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
You might of scratched something in the screen and broke it. So the best bet is to buy the ifixit 5s screen replacement kit.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
thanks i will resort to that after disconnecting and reconnecting the battery
von
Did you unplug the battery before unplugging and plugging in screen cables?
If not:
1. Unplug the battery
2. Unplug screen cables
3. Plug back in screen cables
4. Plug back in battery
5. Plug back in home button cable
6. Turn phone on again.
If still same issue, screen needs to be replaced as the screen has gotten damaged. You are seeing backlight but no display which usually is a bad screen.
Bewertung 0
1 Kommentar:
Hi, No i didnt unplug the battery but I will try that. thanks
von
Antwort hinzufügen
has wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,313
