Replaced battery. Now the phone is stuck in a random boot loop. Help!
Ist dies eine gute Frage?
Try a new battery and also the old one to see if it does not loop anymore. If it continues plug the phone into iTunes and update 1st. If that don’t work then I would suggest a restore. Remember when you restore you will loose all your information. Thanks and Good Luck
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 41
2 Kommentare
Reset didn’t help. Phone gives code 4301. Don’t think the part is bad. Wasn’t bad before the replacement.
von Hank Hankins
If you did not have an issue before the battery replacement then the chances are that your replacement battery is defective.
If the apple logo disappears immediately after charging cable unplug then you know the battery is definitely faulty.
von Ben
