Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Not Charging after replacing battery
I was trying to replace the swollen battery in my daughter's iPhone 5s with a recently purchased and functioning iPhone 5c battery. I have replaced batteries and screens on the iPhone 5c devices several times, so I am familiar with the care needed to not damage ribbon cables and connectors during the swap. After replacing the battery though, her iPhone will not charge. I removed the battery and put it back into the iPhone 5c and it charged just fine. Also, when the battery is charged, I was able to sync the iPhone 5s to iTunes and saved a back up of her files, photos and music. I checked all of the connections several times, including the small single wire that plugs in near the battery plug and the plug from the charging port. I do not have a USB Ampmeter to properly test it as I am a DIY type. Any thoughts on what to look for?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Either the charging port is busted or the Tristar chip needs replacement which requires micro-soldering work done on the phone. You can find reputable repair shops that offer a no-fix no-fee model to get them to fix it for you.
You can quickly test tristar by unplugging the battery then plugging the charger in and see if it shows apple logo or not, if it does not then the tristar chip is not. Usually I would test another charger port if possible to rule that out.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So, without the battery installed, if I plug the iPhone into the lightning cable and charger to power, I should still get the Apple logo? I tried it, I put the screen back on but did not reconnect the home button and plugged it into charge, I did not get the Apple logo, that means the chip is busted. Is that correct?
von
Yes if you can't get Apple logo to appear when screen is connected and battery unplugged Tristar chip needs replacement.
von
The 5C battery is not the exact same as the 5S battery even though it does fit. Try ordering a 5S battery and see if that fixes the issue.
Bewertung 0
1 Kommentar:
They both work vice versa On 5s and 5c, that's not the issue.
von
Antwort hinzufügen
Donny Sanders wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,797
