Why does my scale show out2 or 0_Ld?
Why is my scale reading out2 and 0_Ld after I turn it on and why cant I recalibrate it?
Ist dies eine gute Frage?
Hi ,
Is the weigh plate sitting correctly?
If it is then it seems as though a weight sensor may be faulty and is registering a reading when it shouldn't (O-Ld = Overloaded perhaps), or its' control board has developed a fault.
Here is a link to the ifixit Ozeri Pronto ZK14-S Wire Replacement guide which may be of some help.
War diese Antwort hilfreich?
I managed to fix the Out2 error problem and I don’t think it has anything to do with overloading or calibration. Take out the battery. Then, take the 2 halves of the scale apart by undoing the 2 screws underneath the CE label on the back. Then you need to carefully clean around the 2 buttons - I used a very fine steel pick. A thick needle would probably work as well, just gently scrape around the buttons from both the outside face and as far underneath you can get on the inside face of each button. But the magic solution was a very slight spray of CRC where the buttons make contact. I probably sprayed a bit too much, but it worked immediately. Screw the 2 halves back together, insert the battery, job done. My Salter is around 8 years old and hopefully will go another 8. Good luck!
Letzte 24 Stunden: 15
Letzte 7 Tage: 117
Letzte 30 Tage: 647
Insgesamt: 36,184
