Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
I need help with battery
Battery Replecment iOS not calibrating
I replaced the battery about two week ago. Have cycled this battery many tines, but I can’t seem to get iOS to calibrate. When the phone dies, it’ll try and reboot on the dead battery. Also the Battery Health feature (iOS 11.3 Beta 4) is saying that my battery health cannot be determined ever since it’s been replaced. So what is going on? I was going to just put the old battery back in to see if iOS would read the health
Update (03/07/2018)
see the photo
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Did you know how I can fix the problem with the iPhone 6 battery ?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
My guess is that these replacement batteries don't appear to have proper battery information?
Also the reboot issue, probably the cause of an defective battery. Seems to be a common thing with replacement iPhone batteries here.
War diese Antwort hilfreich?
Bewertung 2
Apple tried to pull a fast one:
http://www.businessinsider.com/apple-bat...
https://www.apple.com/iphone-battery-and...
Bewertung 2
I've exactly the very same problem with the batteries on two different iphones with two different iFixit batteries.. The battery seems to behave correctly and coconutbattery shows everything as correct.
I'll contact with iFixit to check what is happening.
Bewertung 0
Antwort hinzufügen
Ethan Olson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 159
