Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
Black Screen but backlight works
Title really says it all. I also get the chime when I start it up and the backlight works. It does the same with different display. I also tried switching the hard disk but nothing seems to work. Any ideas? Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try an LCD cable. If it still has the same issue, and does the same thing with just the charger port, fan and screen plugged in, the problem will be logic board related (probably LVDS_IG_A_CLK circuit issue, usually L9080 burns out when the screen is messed with, so it sits on a black screen). What is the history of the device?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I tried switching out different screen and it did the exact same thing. So I guess it’s the logic board. Luckily they’re pretty inexpensive online. I got it for like $80 like half a year ago and it worked fine until one day this happened. Anyways thanks for the advice.
von
Antwort hinzufügen
Leon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 130
