Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Why wont my screen work?
So its been doing this for a while I have hooked it up to an external monitor and the macbooks display doesnt come up at all. I can shut the laptop and it goes to sleep and the camera works fine. There is no cracks on the screen it looks perfectly fine. The computer works well since I tested it on a monitor. Just nothing is being displayed
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Update : I installed windows and the screen lights up and is detected but its still just black
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Use a flashlight shining it through the Apple logo in the lid. Are you able to see faintly your the desktop and its icons?
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
No the screen is not detected at all. All the functions (camera, close to sleep) work apart from the screen and apple logo. It looks perfectly fine
von
I have tested it on my monitor and the pc is functional
von
OK lets try this again as you missed the point! Use a flashlight to act as a backlight by shining it though the lids Logo. Are you able to 'see' the faint outline of your desktop icons??
This is a diagnostic step to isolate out what needs fixing,
von
Do you have discord
von
If you don't answer the question I really can't help you.
You have to come to the table at least try to help me help you. Its not like I'm pulling teeth here a simple answer is all thats needed.
von
2 weitere Kommentare anzeigen
you have a driver issue
Bewertung -2
2 Kommentare:
How do I update drivers
von
* Click on the Apple in the upper left corner of the screen
* Select "Software Update..."
* Any updates available will be listed and able to be downloaded or you will be told your software is up to date
Since u cant see your screen hook up external monitor and see if it will pick recognize.
von
Antwort hinzufügen
Matthew Cawley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 75
