Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
795 Fragen Alle anzeigen
I disconnected my LCD screen when battery was still in. No backlight.
I disconnected my LCD screen on accident without removing the battery. I smelt a burnt fuse smell. When I use my new LCD screen there is no backlight. I checked the fuse with the small dot on it, and it looks intact. Do I need to replace the fuse regardless? Do I need board repair? Any help would be appreciated.
Thank you for your time!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Yes, I can log on to my home screen.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You'll need to test continuity of the fuse a visual inspection is often not enough.
But lets see if the backlight fuse is blown by using a flashlight shining through the Apple Logo. Are you able to see the desktop icons?
Update (03/13/2018)
Well, you're lucky! The backlight logic is damaged. Hopefully its just the fuse link.
At this point I think you'll need to visit someone who has the needed parts and micro soldering skills.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yes, I can log onto my homescreen.
von
Antwort hinzufügen
Daniel Castro wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 46
