Zum Hauptinhalt wechseln
This an 8 inch light blue tablet, with dual cameras and is for students and home use.
Tablet will not turn on
I can't get the table to turn on it shows that it is fully charged.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I forgot I had this model in a bottom drawer. It has been 3 or 4 years since I last used it. (Flaky power connector).
I started Finding out when I plugged in the supply It showed a red light that it was charging and then get this battery icon showed and it still had over 75% battery power. It took me several attempts to start it. So I just let it charge and when it was charged after several minuets I just gave up. Then I tried to start it and behold A word Nextbook showed up on the screen for a several minutes (7+). Then It changed to a scrolling display with the same Name. So again I just left it do its own process for several Minutes More.
Then it started to work!!!! So be patient. Now i started to get the settings and more. Experiment, there was more on the tablet than I knew about. Hope this note Helps!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tom Acosta wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 334
