Zum Hauptinhalt wechseln
The Discovery Series I was introduced into the United Kingdom in October 1989.
3 Fragen Alle anzeigen
97 disco Barely running After warming up
My 97 Land Rover discovery starts acting up once it warms up....such as, misfiring, backfiring, no power, can't go over 40mph down hill, barely goes 10mph up hill. After 40mph, when I push on gas pedal it does absolutely nothing. The same effect you'd have if You just weren't pushing it at all. Once it drops below 40mph the gas pedal registers again...... Any suggestions?
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
If you can get it scanned, do that first. See what codes are coming up. Also vacuum leaks will cause all kinds of problems. Check all your vacuum lines for splits, breaks or brittleness.
von
We put a scanner on it and it comes up with codes for o2 sensors, camshaft position sensor, random misfire, and then some others that say check service manual. About 10 codes altogether.
von
We did however find a vacuum leak but didn't help after fixing it. And thank you for your comment I'll take any advice I can get
von
@adeterding any chance you can post the codes on here?
von
Camshaft position sensor is an important one. Will cause what you describe. Could also be the reason for setting the random misfire codes. However as OT03 mentioned, would you mind posting all your codes so we can better help you diagnose your issues.
von
Einen Kommentar hinzufügen
1 Antwort
Sounds like one or both of your catalytic converters are plugged. Simple test, remove exhaust at the header, put on your ear plugs and fire it up. Once it's warm, if it's not doing it, it's definitely your cats.
Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Amber Deterding wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 163
