Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
Best bluetooth antenna for BCM94331PCIEBT4CAX
Goodmorning everyone,
someone would advise me which of the following two bluetooth antennas is best to use with the wifi / bluetooth (4.0) module BCM94331PCIEBT4CAX for a "MacBook Pro 17 Late 2011"?
1. K17 056-3518-A
2. 631-1570-10
I ask which of the two antennas will be able to offer greater coverage and stability of the bluetooth signal.
Thanks for the assistance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Neither of these are the correct part.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This is the correct part Unibody MacBook Pro 17 Airport Antenna (2011) - Apple P/N 631-0890-B. There is no options here.
War diese Antwort hilfreich?
Bewertung 1
You'd be better to get a new dual band usb AC wifi/bluetooth 4.0 combo dongle for a little more (prob about 50.00 and this antenna only is 27 and tax plus shipping and also used.....) and you'd have AC wifi and newer Bluetooth, but it is a usb connection instead of internal so unless you REALLY want internal only you'd gain much more with a newer AC wifi/BT 4.0 dongle for a few bucks more.
Bewertung 0
1 Kommentar:
Most WiFi/Bluetooth dongles don't support MacOS so that won't really help here.
The posters focus was on Bluetooth not WiFi and he was looking for a more powerful internal antenna which doesn't exist.
von
Antwort hinzufügen
Alex wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 331
