Zum Hauptinhalt wechseln
Mobilversion von Apples iPad Air der 2. Generation. Modellnummer A1567
87 Fragen Alle anzeigen
What the problem is, the whole display or controller?
Hi guys! I have an iPad Air 2, everything worked well, I’ve updated to iOS 11, everything was right. A few days later the touchscreen didn’t work (the iPad didn’t fall into water or something else, it just stopped responsing to the touches), the display is working (no defects), but doesn’t response to the touches, every button works....only the touchscreen doesn’t work. I have done hard reset (entered the recovery mode and then restored), it didn’t help.
The question:
What the problem is? Do I have to replace the whole display or maybe there is a chip or other electronic element that controls just touchscreen? I think there will be a big difference at price between replacing the whole screen and replacing a little chip.
Thank you
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Was the display replaced in the past?
And no, you can't just replace a controller chip.
von
No, nothing had replaced ever. It’s the first problem ever.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
My suggestion to you:
1) Backup your iPad in iTunes
2) Download the older full firmware file for 11.2.6 from here.
2) AFTER the download completes, put your iPad into DFU mode and plug it into iTunes
3) it will ask you to restore.
• on a PC hold SHIFT+Click restore, and select the firmware file you just downloaded.
• on a Mac hold Option+Click restore, and select the firmware file you just downloaded.
See if your display works again or not. If it does, wait until the next iOS to update.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Murat Akmammedov wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 84
