How to reset Amazon Echo 1st and 2nd generation?
Give your suggestions how to reset echo device?
Ist dies eine gute Frage?
Hi @anayadic ,
Here's a link that shows how to reset Echo 1st Generation
Here's a link that shows how to reset Echo 2nd Generation
Hopefully this is of some help.
War diese Antwort hilfreich?
If your Echo device is unresponsive , or something went wrong with your device, you can reset your device. After resetting, you need to register it to an Amazon account and enter any device settings to use it again.
Use a paper clip to press and hold reset button at the base of your device. After few minutes to press and hold reset button the light ring on your Echo device turns orange, and then blue.
Wait until the light ring to turn off and on again. When your device enters setup mode, it shows orange light.
Open the Alexa app to connect echo device to a Wi-Fi network and register it to your Amazon account.
The paper clip reset unfortunately doesn’t work, the blue ring just keeps spinning with no orange light. I’ve unplugged, pressed the reset for 5, 10, 20 & longer, still nothing?
I’ve de register it, still the spinning blue ring…
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 71
Insgesamt: 9,400
4 Kommentare
just find the pinhole on the base or near the power socket and stick sim tray open tool to reset
von margaret.simpson53 Teilen
or a pin , paperclip
How do you reset echo show
von fletcher.jr1940 Teilen
Download alexa app for mac computer – HelpSection
Alexa Amazon Echo Dot it's an upscale and solid contraption, which mean to show customers the things. You can see everything, which you can check out Alexa amazon resonation device. For example, get the new news update, See refrains of the tune, with Amazon music, check out Audible Audiobooks and essentially more. The customer can set the check faces in the spot device, to suit your style. For Instant Help or Echo Dot Setup, visit https://www.smartechoguide.com.
von SmartEcho Guide Teilen
