Zum Hauptinhalt wechseln
My ipod is locked and I forgot the password
I need help unlocking my ipod touch
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 51
1 Kommentar
Sankaraperugu
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
If you connect it to the same computer it is "paired" to for syncs, you can force the pass code off:
  1. Connect your iPod Touch to iTunes
  2. Press or Hold the power and home keys 10 seconds.
  3. Screen goes black, now release the power button
  4. Make sure you do not release the Home key until your iTunes says "We have detected an iPod Touch in recovery mode."
  5. Restore the iPod
You will, of course lose any content which has not synced back to itunes from the iPod...
See also Apple's tech note on this.
War diese Antwort hilfreich?
Bewertung 27
13 Kommentare:
David Iwanicki's fix also works if your Ipod is stuck in a loop it is step 4 that saved my ipod 32 gig
now i got one more to fix
von
Works 100%, thanks
von
thanks alot great
von
Thank you so much, I goggle on how to unlock iPod touch this was best answer by far, I looked like a pro to my son and became the hero :) thank you again.
von
it is not dislaing the passkey part it says that i connect to itune
von
8 weitere Kommentare anzeigen
You may get the solution from here: https://discussions.apple.com/thread/490...
Bewertung 2
try putting wrong password first then hold the lower left button for 5 seconds, then press 3 and hold the lower left button for 2 seconds and repeat... and afterwords when it says wrong password press cancel a message will come up and it will tell you your password is — — — —. (ONLY WORKS FOR IPOD 3G,4g AND IPHONE 4 NO IPOD C OR Cs OR IPHONE 5,5s,6 or 6s
Bewertung 0
1 Kommentar:
what button??
von
Restore/ renew from iTunes
It’s not rocket science
Bewertung 0
1 Kommentar:
Except iTunes is a nightmare to navigate 98% of the time
von
Antwort hinzufügen
shad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 64
Insgesamt: 148,539
