Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1502 Fragen Alle anzeigen
iPhone 3GS 16gb problem when drop on the ground
my iphone problem is :
1st
-"restore needed can't make & receive calls restore via itunes".
-"wifi is in grey color"
-"iphone not sync & charge via usb"
-"not detect sim"keep searching network
-charging with ac adapter..when pull out the charger..iphone off
2nd
so i do the "erase all content & setting" in iphone setting.
3rd
now my iphone just stuck at apple logo during reboot.
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
I deleted your other "answer". This is the phone you dropped???
von
yup...and it has 1st problem above after it drop on the ground
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Try connect your phone to computer and enter DFU mode.
To enter DFU mode:
With the phone both connected and turned off, hold your power button for 1 to 3 seconds. Then press and hold the home button without realeasing the power button and count 10 seconds.
Then, release the power button and still holding home button and count 15 seconds.
If you already did that and doesn't work, I would say that some board may be broken. Maybe your dock connector board...
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
i hv done it...and it work in DFU mode..but now i don't know what to do next step..
von
Now open itunes and select restore. It will then install latest available ios.
von
"your iphone "iphone" cannot be restore.error 1601" this message show.
von
At the apple support page thay only say that you must update your itunes/quicktime to fix the error 1601.
Look for the error on google and ou find some guys that found themselves stucked on this error due bad jailbreak or something and they got out of the problem doing another jailbreak with another hack program.
But as long as your case is about hardware damage, I think it's not a software issue.
von
i'hv send it to technician to check for it...thank's for the answer.. :)
von
try uninstalling itunes and then re installing the latest up to date version.
It may be easier to visit a friend and use their version of itunes.
It may be that when you dropped the phone you have damaged the dock connector and this is why you are having the other problems also.
http://www.iphone4jailbreak.org/forum/ip...
http://ijafri.com/2011/02/21/fix-itunes-...
Bewertung 1
1 Kommentar:
von
Antwort hinzufügen
ken wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 1,876
