Zum Hauptinhalt wechseln
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
20 Fragen Alle anzeigen
I shorted out my usb port
tyler.norton82 less than a minute ago
I shorted out my laptop, I was trying to plug my headphones in the dark and it went into the usb port. When I went to turn it on, the fan starts the power light turns on for about 5 seconds, but the screen doesn't turn on. Then it shuts off and tries to start again, over and over. U my lap top is a Acer aspire e15 e5-511-c0pc. I'm not to familiar with laptops, I have once taken it apart to replace the hard drive. Can I take out the memory and hopefully fix it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Unplug remove battery hold down power button for 30 seconds grab a door knob to make sure to discharge any static from your body tske paper clio and look i side usb and strighten all the pins. That should work if n o t replace usb port its shorted out
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@retlaw132002 thank you for your solution comment.I really appciate
von
Antwort hinzufügen
Tyler Norton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 398
