The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Hi @rh001 ,
A bit more detail will help us to help you.
What are you trying to do?
For example are you trying to copy documents by loading them in the ADF or in the paper tray?
If so what is the type of document i.e. what is the paper thickness and size etc?
What make and model is the computer that the printer is connected to if you are wanting to print to the documents that "will not feed"?
von jayeff
