Zum Hauptinhalt wechseln
Geräuschisolierende In-Ear-Kopfhörer mit ControlTalk-Mikrofon. Hergestellt von Monster als Teil der Kopfhörer-Produktreihe Beats by Dr. Dre. Erschienen im Jahr 2010. Modellnummer: 0000441731.
ibeats wire snapped for no reason, can I re-attach it?
I bought these last summer and for some reason the area that i put blue linings around snapped off, now i can only listen to music with one earphone instead of 2.
I really want to listen to music again with both earbuds and my question is how can i reconnect the wire and make it work again, and if it is even possible?
i used to cut wires and re-attach them on other electronics so i guess this will maybe work for my earphones too.
thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You can try, but it is not sure you will be able to fix it. You will need to find out if there is any issue in the cable first, if not, just reconnect it and make sure it stay there. For the 95% of the chances, it will not work, but trying does not harm!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I will have to open the small box where the cable gets divided in two and reconnect it there, be carefull with the other earphone side cable
von
Antwort hinzufügen
Julian Blue wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 573
