Engine leak oil also blows back oil from the dip stick
My car has an oil leak. It also blows back oil through the dip stick
Ist dies eine gute Frage?
Sounds like your PCV valve needs replacing.
War diese Antwort hilfreich?
mike vernon possibly blown piston rings. Check or replace your PCV valve as suggested and then do a leak down test. It will tell you a bit more about what is going on with your Camry
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 59
