Zum Hauptinhalt wechseln
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 Fragen Alle anzeigen
How do I open it up?
So i dropped my headset and i didnt see anything wrong with it untill i tried to turn it off.
it seems to power button got stuck and cant fully move to the top, so i want to open it to see how but i cant seem to find anything on youtube and i cant seem to figure it out myself.
if anybody can help me that would be nice.
thank you and have a nice day
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
4 Kommentare
Happened to me exactly the same.. what did you do in the end?
von
* What size is that triangle bit?? I just ordered the pro-tech bits and none fit the headphone.
von
Is their anyway I can turn it on without that even if it’s stuck
von
Use a very small torx but for the triangles. Pop the knurled right off the outside of the headphone to reveal the screws
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
I have a more complete writeup here How can I replace the headband wire?
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
For anyone having the same problem:
At first, remove the two triangle screws from the outside
Then just lift up the plastic-ring (it’s glued) - under it there are 4 screws, if you remove them, the casing will open up
Bewertung 16
8 Kommentare:
how do u even lift up the plastic-ring? it seem impossible
von
its kinda difficult, just use the "Jimmy" Tool or some thin plectrums
von
Before I tear the earpiece apart… is it worth while? My button is stuck but still operational. Will still turn on / off. Thanks :)
von
What size is the triangle bit?
von
Warren Duan: I used a flat head screwdriver that fit tightly between two points of the triangle screw and they unscrewed easily.
von
3 weitere Kommentare anzeigen
Hi there!, so this happend with me too and when I tried to click the power button of my JBL headphone it wasn’t doing anything. So to fix this there is no need to buy a new pair or get it fixed. All you need is a safety pin, unless you are careful and you don’t get any scratches all you have to do is try to pop it up but the side which has been buried
JUST LIKE THIS :):
Bewertung 5
4 Kommentare:
Hi there Kashvi,
I think it doesn't the same model, in E45BT the power button is not pressed, it's slide button.
von
Thank you so much kashvi…it worked!!
von
Yes its worked!!👍👍
von
thank you so much youre my savior i was sobbing bcs i love these sm and live for music and podcasts and you saved me tysm omg
von
If these are anything like the other headphones I’ve disassembled there should be 3-6 screws hidden under the earpad foam. They will likely require a proprietary JBL bit. Here is a link to some triangle bits, one of which should be the correct size for your headphones. Hope this helps!
Bewertung 1
Has anybody finally found out why the slide button gets stuck before it reaches the end position? And maybe if there could be a fix without completely opening the affected ear shell?
Regards,
Wolfgang
Bewertung 1
I would say that some of the hardware in the head phones might have gotten messed up but that is probably not likely.
Usually the headphone will work after being dropped because JBLs are pretty tuff. Depending on the hight dropped, if they are somewhat new, I would ask for a refund because they are meant to be pretty tuff.
Bewertung 0
Antwort hinzufügen
Guy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 195
Insgesamt: 28,729
