Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
"Settings" for backlight repair?
I have done several motherboard repairs, but always have problem when i repair the backlight.
What I have heard you can change both BL Ic, Diod and coil to make sure all parts are good.
Question is what is a safe working temperature for removing them and then install new ones? On the ones i have tried I always have problem to remove the coil.
In what order do you install them? Are some of the components more "scared" for heat?
All tips will be appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The coils are difficult to remove without damaging them as they are made with some form of soft graphite (or something). They may also be glued in place prior to being soldered in places so they don't float around during the soldering process.
If you do a full replacement, what some call a windshield wipe repair, then I would apply the same temperature as usual ( I use 380C at low airflow on a Hakko 810) but make sure to heat sink the CPU and generally point your airflow away from it. You will probably want to pry the coil once the colder is flowing in that area so you don't leave heat on their longer than necessary. Practice on some dead boards.
For the rebuild, I would definitely start with the smallest components (C1513 & D1501 make sure R0412 is still there) first as you will have lots of "elbow room" to work without the big ones in place. Then it's really a matter of preference but I would keep the IC for last. The other components will help guide you for it's proper alignment and you don't heat it unnecessarily either. Keep in mind you are next to the CPU so heat transfer must be limited to what is essential.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Johan M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 121
