Zum Hauptinhalt wechseln
Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2228 Fragen Alle anzeigen
How can I improve the grip on the 54-bit kit screwdriver?
How can I improve the grip on the screwdriver in the 54-bit kit? The shaft of the screwdriver is completely smooth except for 3 rubber rings that rotate in place when you turn them and some dimples that don't seem to do much. I'm having trouble removing screws that are screwed on really tight; I end up using a different screwdriver almost every time because I can't seem to get enough grip on the kit screwdriver.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I have the kit you have and also the smaller kit. The smaller one has a larger diameter handle and it feels like I can get about double the torque on it. It's an inexpensive set plus I don't have to change bits as often when using both drivers. Here it is: [verlinktes Produkt fehlt oder ist deaktiviert: IF145-028]
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thanks, I purchased that kit hoping that the screwdriver in that one is better. Plus, I needed bigger bits for bigger things like desktop computers, so it works out.
von
Glad I could help.
von
Try adding some sugru to customize it to your needs!
Bewertung 0
Antwort hinzufügen
danieltian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,733
