Zum Hauptinhalt wechseln
Anleitungen und Hilfe für verschiedene TV-Gerätehersteller und -typen.
9055 Fragen Alle anzeigen
Why are there horizontal lines and double images
Sony Bravia KDL46W4100 LCD TV is 2yrs old, when I first power it up now there are horizontal lines and double images just on the right side of the screen, the left is fine. This will go away after 5-10 minutes then the picture looks good. I had someone tell me to power off, unplug the TV and wait a couple minutes and plug back into a different outlet but got the same results. I also replaced the expensive surge block it was plugged into as requested and it still does it.
Chris
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
6 Kommentare
Did you fix the TV?
von
Previously, I'like sony, good quality and famous brand BUT NOW SONY IS THE BAD QUALITY, TOO MANY LCD/LED TV PROBLEM, WHY AFTER GUARANTY EXPIRED, DOUBLE IMAGE ATTACK MANY TV SONY, THIS IS SONY TIMER?
I DECIDE, NO MORE BUY SONY PRODUCT AND I WILL SAY TO ALL MY FRIEND IN INDONESIA, &&^& QUALITY
von
I agreed with you he told above is very correct.I DECIDE, NO MORE BUY SONY PRODUCT AND I WILL SAY TO ALL MY FRIEND IN indai
von
Sony is now depending only on their Brand name ? . Poor you Sony people , you do not know how we earn our money ? Do you think you can loot us by supplying poor quality products ? .
von
Dont buy Sony, very bad quality panel, plus very poor service center. and most of all the ^!&$@*%%$%*^* charge big price for it. Dont buy Sony and Samsung, very poor quality.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
My first impression is that you have a component/IC on the logicboard that has a bad solder joint or BGA and as the unit heats up proper contact is made. The only other thing that makes sense is 1 or more capacitors are going out. They are loosing their charge when the system is powered down and not fully recharging for the time frame you speak about. Your TV needs some attention from a qualified repair person.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I have this problem too ....
von
tv repair expert - 9372739147
von
Hilfreichste Antwort
More likely to be T-CON board problem, if you Google "SONY LCD TV PANEL PROBLEM", you will see why.
Learn more here;
SONY T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
http://www.scribd.com/doc/25276757/E4095...
PDF download: http://www.mediafire.com/?zzjygannjty
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352...
Bewertung 2
3 Kommentare:
Also look for 'Tab bonding' at badcaps.net
von
Hi everyone...
My videocon 32 inch lcd tv shows double image on the screen .....
I think its probably short in the panel but dont know which wire to cut...plzzz help me...if anybody knows
von
von
Antwort hinzufügen
Chris Polley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 46,910
