Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Microphone not working on calls.
So, I’ve got a customer and they’re proposed this:
“When calling, it’s as if the microphone isn’t connecting because no one can hear me. They can hear me fine if I put it onto loud speaker though”.
Just wondered if there were any ideas on the issue and what needs replacing?
Wasn’t sure if it were top microphone, bottom microphone or a speaker.
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You need to test it because what the customer says may not necessarily be exactly what they mean.
I've had many cases where they call the earpiece speaker a microphone.
If microphone or speaker too quiet you clean the filters for them. Personally I find 99% isopropyl alcohol brushing to be the best solution, don't douse them in that of course.
If it's not working you will have to replace the part.
For earpiece not working sometimes it's the front camera ribbon assembly cable being ripped or the earpiece speaker needing replacement.
For quiet earpiece, same thing with cleaning. You will also need to open it to clean the filter on the earpiece itself as well, could also have metals stuck on the earpiece speaker which causes the issue too.
And worst case scenario is the audio chip going bad, that requires tools and experience in microsoldering to do so.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sam Mileberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 1,005
