Zum Hauptinhalt wechseln
Device repair and information for the Plantronics Backbeat Fit 2100, wireless sport headphones released in August 2016.
19 Fragen Alle anzeigen
Can I disassemble my Plantronics Voyager 5200 charger case
Hi. I have problem with the top connector in my Plantronics Voyager 5200 charger case.
I need to open the unit but I can´t
Can yo give me a video explain it?
This is the charger case: https://www.amazon.com/Plantronics-Voyag...
Thanks !!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
do you any ides of what you're going to do if you get it open?
von
Maybe. But i know how unblock and open it
von
Do you have any pictures? is there enough space to add a wireless changing inductor? My handy supports wireless charging of equipment - it would be great to upgrade it ;-)
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Yes, you can open this case. There are two small hidden screws. They are near the hinge, and under the rubber liner on the inside of the case. You call peel it back with a small, flat tool and maybe some gentle heat to soften the adhesive. Start in the corner near the hinge, where the ear piece sits when the headset is stored in the case.
After removing those two screws, you can pry around the top edge of the case to release the snaps and it should come out. There are some small magnets to retain the headset, so don’t lose them when opening.
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
i had a usb dongle stuck inside the case that i needed to get out. disassembling helped.
see post below from another user with pictures.. that further helped locate those two screws "inside" the case :)
von
Before you tear it up, I'd check to see if it is still under warranty.
https://www.plantronics.com/us/en/suppor...
DATE CODE EXPLANATIONS
Each Plantronics unit is imprinted with a date code to assist in tracking warranty information. The date code can be found on the plastic housing on the top half of your headset or, if your unit is an over-the-head style, the date code is located under the foam ear cushion. For more information you can contact technical support.
WARRANTY TERMS
Warranties for products last one, two, or three years (depending on the product and country you are in) starting from your original date of purchase or according to your products’ Date Code. For more information you can read the worldwide limited warranty terms and conditions.
Bewertung 2
Thank you gee-one for explaining this, I've been struggling to open this thing without ever realizing that there even was a liner!
As noted in the accepted answer, the two screws are in front of the hing beneath a rubber liner inside of the case that the earpiece rests on. I was able to slip a thin metal jimmy under one edge of the liner and lift it up pretty easily.
Bewertung 2
Hey. did you manage to replace the battery? Any parts, recommendations?
Bewertung 0
Antwort hinzufügen
Esteban Yanson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 76
Insgesamt: 3,665
