Zum Hauptinhalt wechseln
Fully customizable all-in-one workstation. 300 GB SSD / 32 GB max RAM / Windows 7 Professional / Intel Core, Xeon, or C206 Chipset
5 Fragen Alle anzeigen
Does not post, just black screen
Hi
I got Hp z1 workstation with intel xeon and quadro 4000 gpu
the computer wont post, just spins fans and nothing on the screen
i have trouble finding anything on the internet of this issue
can it be bad motherboard, bios chip im not sure
can anybody help?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
seems like i have the same problem too.. How did u get this resolved?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
Here is a link to the service manual for your computer.
Try the procedures found at the bottom of p.61 to see if it helps in localizing the problem.
Also try shining a torch at an angle close to the screen to check if you can detect an image. If you can you have a backlight problem with the screen.
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
It seems that i tried most of these, but the strange part is the pc does not beep or come with any error code, can it be corrupt bios chip?
von
Hi,
Try some simple things first.
Remove the coin cell CMOS battery from the motherboard (power disconnected of course) and then press the power button for a while to drain any residual power from the motherboard. If there are any corrupted settings in BIOS this should "release" them and hopefully restore it back to its' default settings. Reinsert the CMOS battery, plug in the power and see what happens.
Use a DMM's Voltmeter function to check the various power supplies from the PSU to ensure that they are the correct voltage. Don't know your motherboard but usually there is +12VDC, +5VDC +3.3VDC supplied to the motherboard and CPU etc.
Without a schematic of the motherboard you don't know whether the problem is the BIOS or something else not allowing the process to continue to a point where the BIOS software can function. (i.e. perhaps that is why there is no beeps, you haven't got that far into POST. It may not even be starting.
Apologies if you've already done these things.
von
Just tryied CMOS battery method, with no luck, i also have spare powersupply to swap with no luck,
Notebene i got two of this pc at home both with same symptoms
strange i cant find any comments on the internet of this problem
von
yes also tried to swap the cpu ith i7 HD cpu and remove the discreed videocard
with no luck
von
Hi,
Unless you can get a programmed BIOS chip for the motherboard to replace yours (and it still haven't been proved that it is the problem), then without a schematic of the motherboard, it has to be put down to a 'motherboard' problem.
It may have nothing to do with the BIOS.
It may be something to do with the initial power checks on the board that is done, after the power button is pressed, to ensure that the conditions are right for BIOS to even start.
These checks are inbuilt. i.e. voltage levels are detected at various points to ensure that they are correct and the board can function OK for the BIOS to proceed.
There may be no comments because mostly people don't have access to board level information and flowcharts etc as to what happens when you first press the Power button. The fan turning on may be just to allow it to get up to speed so that it can be detected as working by the BIOS for instance, I don't this for sure but it is possible.
von
2 weitere Kommentare anzeigen
yes just remove the video card, just stay smart, do well
translated by goole
Bewertung 0
Antwort hinzufügen
Palli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 2,839
