Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Home button intermittently working
Had a broken screen replacement done recently by a 3rd party about a month or so ago and now the home button works intermittently. I have to click it a bunch of times before it registers.
The home button itself clicks fine and is very responsive so I don't see a problem there. I took the phone apart and carefully removed the home button, ensured everything was clean. The cable looks fine, as does everything else. I reseated it, ensured it was in tight, ensured the screws were in tight and put everything back together. Still no change.
Close up of the button while disconnected:
Any ideas what to check next?
Update (05/21/2018)
I took the back off. I wonder if this could be the issue (small kink in cable)?
Update (05/22/2018)
Replaced the back plate with a brand new one, was careful to ensure the flex cables were fine.
Home button still doesn't work, at least works if I press real hard about 3-4 times then it registers.
Any other thoughts on what to do next?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Check the home button flex that plugs into the motherboard that could be loose or something. If that doesn't change the issue I recommend getting the back LCD plate replaced. That could be the issue. Normally, I see this problem on iPhone 6s because the home button flex is within the display unit. Let me know if this fixes the problem!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I would change that out. That defiantly change that back plate that could be the issue.
von
I replaced the back but the issue still persists. It takes about 3-4 hard presses before it will register as a single click. Also, noticed that it says something like "Cannot use touch ID on this device".
von
I have the same problem. How have you fix it?
thkx
Bewertung 0
Antwort hinzufügen
mrl72 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 772
