Zum Hauptinhalt wechseln
The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
Laptop screen wont turn on but keyboard and razor logo will light up
Is there a way that I can get my laptop screen to work again? The keyboard back lights work and the razor logo on the back of the display works when I turn it on. But I get nothing from the display itself.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I am also able to connect a HDMI cable to it and I can get the laptop to display on an external display.
von
The touch screen works. This confuses me.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @birdup
What is the actual model of your laptop?
If you flash your torchlight on the panel, can you see anything on it?
Some issues that could be causing this, e.g. like Faulty LCD module / panel, Faulty LVDS Cable, etc
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
@birdup "the razor logo on the back of the display works" means you have a working backlight. The digitizer is separate from your LCD and right now it appears as if you either do not get a signal to the LCD or the LCD screen is just not working. Since the external display works I would go with a new screen
von
Antwort hinzufügen
Harrison Reisinger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 42
Insgesamt: 7,383
