Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 - screen replacement - no auto-brightness - laggy screen
I replaced the screen on my iPhone 6 with the iFixit iPhone 6 LCD Screen and Digitizer Full Assembly. Since the replacement, my phone no longer auto-adjusts the screen brightness and the screen has become very laggy, sometimes causing the screen to freeze, sometimes opening things I didn't touch, and sometimes not recognizing my touch at all.
I took the phone back apart to make sure all connections were reseated properly, however the problem persists.
I tried to remove the front facing camera and ambient light sensor from my original screen in hopes of replacing that part of the replacement screen, but the ambient light sensor disconnected from its cable in the removal process, so that is a no go.
I never had either of these problems with the original screen. Is this happening because my replacement screen is faulty?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes the screen could be faulty for the random touching, no touching, and freezing. However, for the auto brightness that is dealing with the proximity sensor. Make sure the sensors are seated well into the screen. and look for any damage to the proximity sensor flex cable. If there is damaged you can get a replacement for $7-$15USD on Amazon. But the screen is a bad screen you need to return it and get a different one.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Emily Resner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 183
