Try this.
Open Word
Click on the Office Button -> Open
Single-click on the file you want to open
In the lower right corner, where the Open button is, click on the arrow beside it and select Open and Repair
If it is indeed a corruption then MS Word would complain file is corrupted.
From the gibberish you posted, it is likely that the file was saved in an older format of Office document without proper UTF8 encoding instead of a file corruption.
Do the following to do some checking (assuming you are using office 2010):
- Back up your file before attempting, and if any of them fixed your issue, you don't have to try other options
1. Open the file in office word -> save as into rtf file -> close the office -> re-open the rtf file (does it display properly?)
2. Open the file in the office word along with another blank office document -> press ctrl+home -> press ctrl+shift+end -> press shift+LEFTARROW -> press ctrl+c and paste into the blank office document (does it display properly?)
3. Try to remember what the supposed original language of the document is, then change your computer's region and language into that specific country's setting by going to control panel -> Regional and Language Options -> restart your pc and reopen the document.
If none of these fixed your issue, I’m afraid your document is lost forever.
or you can try to use repair word document
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
