Zum Hauptinhalt wechseln
The Huawei MediaPad M2 is a full-sized Android tablet released in February 2016. Includes models M2-A01W (Wi-Fi only) and M2-A01L (Wi-fi/3G/4G).
4 Fragen Alle anzeigen
I can do with the error that I met on my device in CorelDraw?
Recently, I did not fail to complete important work. Several files opened in CorelDraw with errors - a valid workpath path was not found. And I have no idea how this could happen. I hope for your help. Perhaps someone here has already met with a similar problem.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There are many variants of coreldraw file recovery, but the most easiest are the following...
By guide
Corel makes a .BAK backup file that has the same name and is usually located in the same folder as the original file, but can also be located in the /Programs/Corel/Programs/Draw folder.
When a file is corrupted or otherwise damaged, find the .BAK file, open it, and copy it (save as) over the original corrupted file.
Or by articles, tips, etc...
https://support.corel.com/hc/en-us/artic...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
NoelleFoley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 370
