Zum Hauptinhalt wechseln
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 Fragen Alle anzeigen
Need a brake line diagram for 2002 cadillac eldorado esc
I need a brake line schematic for 2002 cadillac eldorado ecs so I know the size of the line I need and the size of the fittings on each end. The part number for the line i need would also be helpful.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@dccorrado It is a royal PITA to bend your own line and to apply the fittings etc. If you have never done this it will be extremely difficult and cumbersome. It is way better to replace the lines with premade ones. Depending where you are you can get those from your dealer or even aftermarket.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
jackie corrado wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 201
