Zum Hauptinhalt wechseln
Die Nikon 1 AW 1 ist eine wasserdichte Kamera aus dem Jahr 2013. Diese Kamera ist WLAN-fähig und zeichnet mit einem 14,2-MP-Objektiv in 1080p auf.
Nikon 1 AW1 WP-O2000 O-ring Discontinued
Hello,
It appears that nikon as discontinued the Nikon 1 AW1 WP-O2000 O-ring. I had a chat with nikon rep and they wanted me to send it in for service instead of selling me an O-Ring.
Has anyone used any non-oem O-Rings or know what size/type I should buy as a replacment?
Thanks - Justin
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Justin. I am not sure where to get a genuine nikon o-ring, but if you have a caliper or fine measuring implement, try measuring the o-ring from the nikon camera that failed and ordering a replacement off McMasterCarr. McMasterCarr is fabulous for this application. They sell many types of O-Rings for various applications.
I had to order a replacement O-Ring for the top sprayer arm for my GE dishwasher. Ge only sells the O-ring as part of the top sprayer kit, which retails for $100. I searched McMasterCarr and was able to order an FDA listed food-safe O-Ring that fit within the temperature requirements of my dishwasher. Pretty fantastic.
For o-rings, it is best to buy a few around the size you need. So one or two sizes up in cross sectional width and maybe one or two larger in outer diameter. Just in case you measured wrong, you don't have to wait another week to get the right part! O-Rings are usually pretty cheap, so it's worth the redundancy.
Good Luck!
War diese Antwort hilfreich?
Bewertung 2
I have ordered an O-ring from McMaster-Carr. I had my mechanical engineer take the measurements, and we settled on this one. It’s made from Buna-N, not silicone, as the silicone rings were speced out a bit harder than we judged the Nikon ring to be. These arrive soon!
Be careful about size. It’s ok to stretch just a bit, but you absolutely do not want the O-ring to be too large, or the integrity of the lens seal will be compromised. Also, make sure the ring you buy is resistant to the usual silicone/PTFE grease you’re going to use on the ring.
https://www.mcmaster.com/2418t155
Bewertung 2
2 Kommentare:
For anyone interested, I tried the O-rings listed in this post as well as these (50mm ID-3mm wide):
https://www.mcmaster.com/1174N613
I haven't done a proper water test with it yet (still have some OEM rings left to use before I risk it), but the 50mm ID-3 mm wide rings are a much closer match to the OEM rings than the 2" ID-3/32" wide rings. When mounting a lens the 3/32" feels too loose, 3mm has a very similar feel to the OEM.
von
Hi Michael
Have you water tested the o ring you mentioned above, on your Nikon AW1. Which size did you end up using
von
Antwort hinzufügen
Justin Wade Thornton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 1,870
