Zum Hauptinhalt wechseln
Repair guides and support for the second generation Honda Insight.
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Does the drivers side switch operate the window on the passenger side?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
William Salzwedel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 357
