Zum Hauptinhalt wechseln
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
Will not load cmos
My laptop will not complete the cmos load
it stops a part way thru the process
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I have the laptop with a friend right now and so cannot suppy the complete series number. However I went on line and found hat that this particular series of Toshiba laptop does not have a CMOS battery but the operating battery is used to boot up the CMOS.
von
Einen Kommentar hinzufügen
1 Antwort
You may have a bad CMOS battery. Test it, and replace it if you aren't sure it is good.
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
The computer does not have a cmos battery The laptop battery acts as the cmos battery.
von
All modern computers have a CMOS battery. On some Toshibas it is soldered on, making it impossible for the user to replace. But I'm having a really hard time getting information on the CMOS (or "RTC") battery for this particular laptop. You put "P55W" as the model number. Is there another number after that? Because there are a lot of "P55W" models listed on the Toshiba website.
von
@mrjimphelps rethink this "All modern computers have a CMOS battery". Toshiba's are actually known for no longer having a CMOS battery. The BIOS settings are now stored in non-volatile memory, instead of CMOS RAM. This negates the need for the CMOS battery to remember the settings for the BIOS.
von
In my opinion, not having a CMOS battery is a poor design. What will happen if you remove your main battery and the AC adapter? Will that reset your BIOS/UEFI settings?
von
@mrjimphelps nobody on here doubts this. Manufacturers are not in the habit of asking consumers what to do. That is the reason for existence of this website.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
slide82iron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 533
