Zum Hauptinhalt wechseln
Alles was du brauchst, um dein iPhone zu reparieren! Von den neuesten iPhone 15-Modellen bis zum allerersten iPhone überhaupt - bei iFixit gibt es kostenlose Anleitungen zum Reparieren und Zerlegen für jedes iPhone und dazu auch die besten Ersatzteile, Werkzeuge und Tipps in der Galaxis.
36474 Fragen Alle anzeigen
iPhone X and 7 get warm
Looking to see if people’s phones match up to what I experience yesterday in a car my iPhone X get pretty through the entire phone when I got out and was able to check the temp with a thermometer the phone was 90 degrees on the back and felt warm against my skin this was just idling in my truck with the ac on. I can easily make both my iPhone X and 7 ramp up over this with just general usage such as browsing the internet or facebook but usually this is under the camera.
Is it normal for a phone to feel warm when idling in my lap while driving with the AC on? The whole phone felt warm at this point. Roughly 80 degrees outside yesterday.
All of this is in Fahrenheit also what temp is your phone f you can check for me. Any thermometer will work.
Thank you so much, also my previous X was replaced I have had this one since Friday, updated to 11.4 Wednesday.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Most phones do get warm while under load or even when idling. A phone is very much the same as a computer, having a cpu, ram, motherboard, a power supply(Battery), and a HDD. The difference is a computer has many options to cool down when it warms up with fans and heat sinks. Phones don’t have the best ways to dissipate heat making them more susceptible to warming up fast. Electronics can handle high temps, but If you are getting uncomforatable with the amount of heat it is putting off. I would suggest turning it off for ~30 seconds then turning it back on. That will allow the CPU to have no work load and cool down.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you sir.!
von
Antwort hinzufügen
cbrewer_4 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 327
