Zum Hauptinhalt wechseln
Erschienen im März 2017, ist das G6 LGs Flaggschiff-Smartphone mit Android 7.0. Dieses Gerät ist bei den meisten Händlern erhältlich. Eine Reparatur dieses Geräts kann die Wasserdichtigkeit beschädigen und das Gerät anfällig für Wasserschäden machen.
56 Fragen Alle anzeigen
How to tell if motherboard has been damaged from a fall?
Dropped it from about 3 ft onto cement, glass is cracked and screen will only display one single vertical line from top to bottom. My question is there a way to tell if just the LCD and digitizer needs to be replaced or is something on the motherboard messed up too? I think I'm handy enough to attempt a screen repair but don't want to burn 100$ on a futile repair. Vibrator motor seems to respond to power button inputs and it does make a sound when power button is held like to power on or off. Thanks for your input.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @dddy ,
The only way to initially tell if there may be a problem is to open the phone and to closely inspect it (use a magnifying glass if necessary) for any obvious physical or possible electrical damage that could have been caused by the fall, e.g. cracked pcb, loose components or cable connections, or “distressed” (burnt looking) components caused by non catered for circuit paths created by the fall.
If everything appears to be OK then a screen replacement (even temporary) is the only way to find out what is really happening with the phone.
Here’s a link to the ifixit LG G6 guide, which may be of some help.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thank you, very helpful information
von
Antwort hinzufügen
Tom Pengelley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 185
