Why is my 2004 Td5 emitting some bluish whitish smoke,?
When i warm it in the morning the smoke is heavy and its embarassing because its heavy and its a cloud of thick bluish and white smoke
Ist dies eine gute Frage?
Hi Sly,
Typically in internal combustion engines, blue smoke is a sign of the engine burning excess oil, and white smoke is a sign the engine is burning coolant. Now a lot of different things can cause these problems. Assuming your Defender has higher mileage, these are what I think could be causing it:
Blue Smoke: Worn valve seals, worn piston rings, worn engine oil seals, or head gasket failure.
White Smoke: Warped cylinder head, cracked engine block, or head gasket failure
Now some white smoke at startup is normal, especially when it is cooler outside. That is usually just steam coming off from the condensation inside the exhaust pipe.
Because you have both kinds only at start-up, I think it could be a head gasket starting to give out. I would have your mechanic check it out sooner than later.
Best Regards,
Drew.
War diese Antwort hilfreich?
I have a 2011 Defender 110 2.4 Puma engine. In cold temperatures <6 C I have a fair amount of white smoke on startup for about 2-3 minutes ( very embarrassing). Once warmed up a bit it disappears and does not smoke again at all during the day on subsequent starts. This is a feature of the Ford engine enriching the diesel air mix to assist with starting and not burning engine oil. My engine oil remains constant between oil service change.
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 51
Insgesamt: 4,130
