Zum Hauptinhalt wechseln
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
20 Fragen Alle anzeigen
PC booting up but screen dark following screen replacement
I have recently replaced the laptop screen as the old one was cracked, when I put the new one in and powered up the machine the screen was extremely dark and the login screen was only visible when shining a torch at the display. I have tried plugging into an external monitor and that works fine. Does anyone know a solution for this or any additional troubleshooting that I can do? Thank you in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
It seems that you have "lost" the backlight power to the screen (assuming that the new screen is the correct one for your particular model laptop (what is the exact model number?) and if it is the correct one if it is OK and not faulty.
(You did have the battery removed from the laptop when you removed/replaced the screen didn’t you?)
Can you try the old screen again to check?
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jack Yates wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 157
