Zum Hauptinhalt wechseln
Ein Desktop Computer ist stationär und in einem Gehäuse untergebracht, getrennt von Peripheriegeräten wie Maus, Tastatur und Bildschirm
20 Fragen Alle anzeigen
pc is slow after formating(windows10)
pc specs:
windows 10
i7-4770
gtx 970
1tb wd hdd
128gb ssd
after i formated to a clean windows 10 everying is slow.
it takes the apps forever to boot up. for example if i try and open battle.net its takes it 2-4 mins to open and if i try to play overwatch the game is slow and it takes forever to load a game. same goes to steam and other apps.
i used wd data lifeguard and the smart status in both is pass.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
How much ram memory is installed in the pc?
windows 10 uses slightly more ram than previous versions, unless you already were running windows 10 before, in which case I would suggest going through the task manager and seeing what is using up the resources of your computer. Are there programs running in the background you don't need?
Also did you get a good copy of windows. I won't harp on pirating or whatever, but many of the torrented versions of windows are unsafe, and may be running software in the background. (Some people have the windows install run cryptomining software in the background, which would make your computer really slow as it is rather resource heavy).
If you have more than 4gb of ram, you should be ok, and it is most likely some form of software infection. I would suggest reinstalling windows from a verified source. Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Yaniv Rainer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 109
