Zum Hauptinhalt wechseln
Reparaturanleitungen für Kühlgeräte, wie Kühlschränke und Gefrierschränke
1696 Fragen Alle anzeigen
Why does water freeze in bottom of fridge?
I noticed water in bottom of fridge turned to ice. Then saw the back had ice. I thawed the fridge fully. After plugging it back in the bottom ice came back after a couple days.
I am not sure what started the problem. First noticed that fridge wouldnt shut. Cleaned the liner and it shut. Then had to take out bottom drawer because the back froze pushing the drawer forward. Like mentioned i unplugged and thawed fridge but ice is back in bottom. I looked up appliance repairs but apparently no one repairs samsung in my area.
Model RS2520SW
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Hi @minnesota1 ,
What is the model number of the fridge?
It may be that the "drain" for the frost melt water (when it is auto defrosted) is blocked.
Also a build up of ice could indicate that the auto defrost cycle is not working or the defrost heater is not working etc.
Is the fridge temp OK (not the freezer but the fridge) or is it warmer than it should be?
von
I cleaned the ice out and after two more weeks ice came back again. Rs2520sw
von
I have the same problem PLUS my fridge is too warm yet freezer is great! Help!
von
@Kerry Richardson
What is the model number ofthe refrigerator?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Cause 1
Clogged or Freezing Defrost Drain
The defrost drain might be clogged or frozen. If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. If the defrost drain is frozen, thaw it out and ensure that the drain is clear of debris.
Cause 2
Drain Strap
Some defrost drains are outfitted with a drain strap. The drain strap is a small piece of copper or aluminum that attaches to the defrost heater and extends partway into the defrost drain. When the defrost heater turns on, heat is conducted through the drain strap to melt away any ice that may have accumulated further down in the defrost drain. If the drain strap is not in place, the defrost drain may be more likely to freeze over.
Cause 3
Drain Heater
Some refrigerators are equipped with drain heaters. Drain heaters prevent the water in the drain pan from re-freezing and clogging the defrost drain. If your drain heater is defective or is not in the proper position, the defrost drain might freeze over.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I will try to see how to check for a clog next.
von
Hi @minnesota1 ,
your fridge has a freezer drain heater shown here as part #42 that you may need to check is working OK
von
could also be icemaker tray is bad and not releasing ice properly. I have to replace my icemaker tray every few years to keep it from filling the ice bin up with a solid block of 2 gallons or so of solid ice. You can stop the icemaker and see if the ice accumulation problem goes away. if so you have found the source of the water that is getting in the bottom of your freezer.
Bewertung 0
2 Kommentare:
The freezer seems to be fine. The ice maker is working normally. The ice build up is in fridge side.
von
Stopping the ice maker didn’t solve the problem, I tried that and having all the ice out.
von
Antwort hinzufügen
christa schutte wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 44
Letzte 30 Tage: 260
Insgesamt: 37,903
