Zum Hauptinhalt wechseln
Sony's 9.2 megapixel HDR-CX675 released in December 2015.The handycam captures 1080p HD recorder.
12 Fragen Alle anzeigen
Horizonal lines on LCD and Tape header noise TRV118
Having an issue with a Sony Handycam Digital 8 that I picked up from a thirft store the other day.
Model: CCD-TRV118
The problem is intermittant....
- The LCD screen will show horizonal lines, usually when I touch or tap the area where the tape is located. This can happen when the tape door is closed, but the problem presents itself better when I try to tap it when the tape door is open.
- Sometimes the LCD screen will stop showing the lines, but sometimes, I have to turn the whole unit off and on again.
- When the LCD sceeen is showing these lines, you can hear the tape deck whirring, like the headers are trying.
I was thinking the camera 'thinks' it has a tape, when it does... maybe something is loose or dirty... However, why would the LCS sceen show pure horizinal multi-colored lines at the exact same time?
Any help would be appreciated!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
IRRC there are 2 ribbon cables that run between the main camera body and the display. One of these cables either has a crack or is loose in its connector inside the camera body. This should be fixable by re-seating the cable or replacing it.
Dan
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
sean gee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 181
