Zum Hauptinhalt wechseln
Support and repair information for JBL E25BT wireless in-ear headphones.
23 Fragen Alle anzeigen
How to fix this problem blinking blue light
When I try to turn it on , the LED flashes white one time and when I continue pressing the button it flashes blue. I would like to know how to fix or atleast reset it to factory settings. Thank you for jbl e25bt
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare:
Hi, when I remove my right earoiece from the charging case it doesnt show any sign of working, but mzy left one does
von
My jbl eb55bt flashes blue but still doesn’t connect.I tried most internet solutions but with no success. Are the headphones damaged internally, because I have tried to connect them to other devices they still don’t connect.HELP
von
Einen Kommentar hinzufügen
7 Antworten
I believe that the blue light you're seeing is the device trying to establish a bluetooth connection. Verify the device you’re connecting to has bluetooth enabled and if you are still having issues it might be due to an issue internal to the E25BT.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
What if its flashing white and blue at the same time
von
Mine does the same, maybe you found out how to fix it??
von
I had this problem, it wont connect to a previous iphone I have been using (to connect). The solution was to have the device disconnected from iphone (forget the device) and have iphone (or your device) connect to it again as if it were the first time pairing it. Works for me everytime
Bewertung 0
2 Kommentare:
I had the same problem, You need to turn of the headphones, when charging off hold the power button for 10 seconds, then remove it from charging and then turn it on, finally it would show on your device and other devices too. If this does not help then factory reset your headphones and try this method again.
von
@danialtahir34 Thank u so much i finally found out how to fix them i thought ill need to buy new ones
von
my bluetooth earbud keeps blinking I tried many ways like the internet said press the volume down and stuff but the best way is open it and using needle or sharp thing break the blue light. Then fixed, just try it, I am not electrician but I tried and worked for me and it will work for you. Hope that helps
Bewertung 0
My jbls just flashing blue and undiscoverable…think they are toast. Have tried everything. Sony here i come!
Bewertung 0
I had this happen before, when the blue lights are flashing it thinks that you're going to connect a new device. Forget the earbuds from your device and connect it again, and then it will work.
Bewertung 0
hi!
my left air bud just blinks blue nothing else, even if its in chargeing box, i tried to trouble shoot it but nothing happens
help please
Bewertung 0
How do I fix my JPL headphones when it blinking blue.. it doesn’t connect?
Bewertung 0
Antwort hinzufügen
Bench gueco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 32
Letzte 7 Tage: 133
Letzte 30 Tage: 648
Insgesamt: 76,901
