Zum Hauptinhalt wechseln
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
Why does the seat post slide down when I sit on it and how to fix this
Hope someone can help.. my seat keeps sliding down when I ride the xiaomi bike even if I secure the 2 seat clasps. Is there another clasp to hold it in place?
Not sure how to fix it so the seat doesn't slide down..
Thanks in advance. :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
According to the included image of this bike, it looks like the bike has a quick release seat clamp. Seat clamps can become loose over time from general use, so make sure to un-do the clamp and rotate the level clockwise to increase the tension the clamp applies to the seat post and then try clamping down the lever again. This will be a trial and error process, so rotate the lever, tighten the clamp, sit on the seat and see if it holds you. If not, rotate the clamp another turn or so and repeat the test again.
Good luck!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hello Sir Anthony Kouttron. Thank you for the response. :) Will try to do as you suggest
von
I tried tightening my quick release clamp but it broke. I bought a new clamp and the seat still slipped, so I tightened it half a turn and it broke again. I have ordered a third one. I'm so frustrated with this, its a great bike but the seat is driving me nuts
von
Antwort hinzufügen
Diane wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,181
